  1. I'M trying to compress more mpeg. time in a regular cd.
    what is the best possible way?
    a small screen size ?
    lower resolution ?
    I need to get couple of 45 min. movies in a cd.
    thank you. I appreciate your comments
    shawn
    Mar 2001
    Antwerp - Belgium (Europe
    For VCD you only can store max. 74min/80min.
    If you need more, use divx or smaller resolutions (but then they aren't (s)vcd compliant, so you can't watch them onto your tv).
